Sensors\Camera Sensor\Create
This tool is accessible via the 'Edit > Sensors > Camera Sensor > Create' menu.
Since version 2.5.6, camera sensors can be created with this function (however it's easier to load them from Bundler files for instance).
For now only the extrinsic and intrinsic parameters can be created / modified (the distortion / uncertainty model can't be setup this way).
Note: theoretically a camera sensor can be associated to any number of 4x4 transformation matrices (association of a 3D rotation and a translation) stored in a Trans. buffer entity. They would typically represent the camera displacement. However no file format allows for loading this kind of data yet...
Camera sensor object (as visible in the DB tree and in a 3D view
