Dip and strike
Colinmazengarb
Dip and strike
Post by Colinmazengarb »
Hi Daniel and others,
I have tried the fit plane function from which dip and strike are automatically calculated. I am not sure that the dip is being calculated correctly. Specifically I have a gently dipping surface and yet dip = 80 degrees (near vertical according to the convention for structural geology). I would believe 10 degrees is more like it. The dip value should be calculated from horizontal. Can someone else check that this is happening to them as well?
Re: Dip and strike
Indeed the displayed value is '90 - dip'. As I'm not a structural geologist, I totally missed that ;).
The bug has already been fixed on the Github repository. It we'll be available in the next release ... sorry about that.
Colinmazengarb
Re: Dip and strike
Daniel,
many thanks for that.
cheers
Colin
