Box orientation parameters in XML for Cross Section
Darius_bd
Post by Darius_bd »
Hi!
Does anyone knows if it's possible to set the Box Orientation when defining a Cross Section via XML? The example file just mentions Box Size and Box Center.
Thanks!
Re: Box orientation parameters in XML for Cross Section
There's no way to set the box orientation. But you can maybe apply a transformation to the cloud/entity before extracting the cross section, and then apply the inverse transformation?
All that with -APPLY_TRANS, the issue being that you need to pre-compute the transformations and store them in 2 separate files...
Darius_bd
Post by Darius_bd »
Hei, that's a good idea! Thanks for the help Daniel
