Hello CC and Daniel,
Any thoughts on enabling a CloudCompare project? This is common in other Geospatial software, the intent is that one can save the project with all the files imported and saved derivatives to get back to it at another date.
Cloud Compare Project
Re: Cloud Compare Project
Well, the way to save a 'project' is to select all the entities in the DB (CTRL+A) and then save the selection as a .bin file.
But I guess we could add a shortcut indeed...
Alternative is to habe everything hanging froma folder, then if you select the folder and save you save to .bin instead of selecting the whole structure.
