View heightmaps in 3D
ThomasRisto
Post by ThomasRisto »
Hello !
Is there a way to load a .tif height map and view it as a 3D mesh (or point cloud) ?
Right now I can load the raster and display it as a plane with a scalar fields, is there a way I can pass the scalar field into the Z coordinate ?
Thank you
Thomas
Re: View heightmaps in 3D
Indeed, as it should have been suggested in the Console (which might not be displayed by default though) you can map the active scalar field to a given coordinate field (x, y or z - 'z' in your case).
Mind that if the units of the scalar field don't match the actual units of the grid coordinates, you'll have to use 'Edit > Multiply/Scale' method to properly scale them afterwards.
ThomasRisto
Perfect once again !
Is there a single thing that you or your software cannot do ? I'm starting to doubt so ;)
Thank you very much daniel
