Collapse DB-tree
SetByFred
Collapse DB-tree
Post by SetByFred »
I’m wondering if there’s an efficient way to move scans that are currently in their own separate DB-trees into the same folder or tree? I’ve imported a registered E57 file consisting of 91 scans from Trimble Perspective. Each scan is located in a folder named after the scan number and contains a "file structure" folder and a scan file named “Scan 0.” It would also be practical if there were a way to rename the files to match the scan number.
Thanks in advance
Re: Collapse DB-tree
You should use the 'Select children by type and/or name' option that appear when you right-click on the top folder (the one with the E57 filename).
Select all clouds this way, and then move them in a folder (you may want to create the folder first, once again by right clicking on the DB tree area).
