Adjusting limit of scalar value
Ingsayyad
Post by Ingsayyad »
I have cloud with intensity value 0-255.
I wan to adjust it:
intensity<40=40
intensity>160=160
Is it possible?
Re: Adjusting limit of scalar value
Nope :)
Or indirectly, by segmenting the cloud in 3 parts (with Edit > Scalar Fields > Filter by Value). Then on the lowest and highest parts you can remove the scalar field, and create a new constant one WITH THE EXACT SAME NAME and the right value. Then you can merge back the 3 clouds.
