Comple with laslib
snfge
Comple with laslib
Post by snfge »
when I use cmake and with laslib, the error show, but if I not with laslib, there no error appear, why?
Could not find the following static Boost libraries:
boost_program_options
boost_thread
Some (but not all) of the required Boost libraries were found. You may
need to install these additional Boost libraries. Alternatively, set
BOOST_LIBRARYDIR to the directory containing Boost libraries or BOOST_ROOT
to the location of Boost.
Call Stack (most recent call first):
contrib/LiblasSupport.cmake:18 (find_package)
contrib/AllSupport.cmake:4 (include)
CMakeLists.txt:97 (include)
snfge
Re: Comple with laslib
Post by snfge »
The folder have the files
Laslib requires BOOST, that's why you need to set it up properly when you link laslib with CC.
And if CMake can't find the right libraries, it's maybe because the ones present in the folder you set are not the right ones (check whether they are release or debug, static or dynamic, etc.). Boost is a monster that's hard to tame.
Personally I compiled liblas myself, and I have not used the one shipped with osgeo4w.
snfge
Post by snfge »
I change something ,so it can complied , but when I run CC, I can see the las in the support list, but it can open the file, the error is "the third-party library in charge of saving/loading the file has failed to perform the operation".
In this case, it may be because the LAS file version is to advanced (1.3+). You can test with the official Windows version and see if the other file filter ('LAS 1.3 or 1.4' - based on LASlib and not libLAS ;) works.
snfge
Post by snfge »
Yes, you are right, I use the liblas, not laslib, but when I use the liblas, the error appear, this hpp files can't find:
#include <liblas/point.hpp>
#include <liblas/reader.hpp>
#include <liblas/writer.hpp>
#include <liblas/factory.hpp> // liblas::ReaderFactory
#include <liblas/header.hpp>
Didn't you say in your previous message that you were able to compile CC with liblas?!
snfge
Post by snfge »
Hi
I am sorry, I mean is when I use laslib, but in CC at lasfilter.cpp, it need include<liblas/point.hpp>, but the laslib not have the file, so I don't konw how to do it
