[Done] Cross on the screen
jfhullo
Post by jfhullo »
Hi all, would it be possible to give the posisbility to the user to remove the cross in the center of the 3D window. For perception it would be greater because when you move the camera you can have the feeling to move the object, and for printscreen to.
Have a nice day all,
Re: Cross on the screen
Ok ! It's now in the "TODO" pipe ... in my head (I really should add such a file somewhere on the SVN repository. Or maybe the roadmap mechanism of Mantis?).
At least this forum will do for the moment :)
Daniel
jfhullo
Post by jfhullo »
Thanks in advance Daniel.
JF
Done!
Now, there's a new option in the "Lights & Materials" dialog (the light bulb icon on the left) to show or hide the middle screen cross.
By the way, I took this opportunity to greatly simplify the GUI parameters related code.
jfhullo
Post by jfhullo »
Thanks for the job Daniel!
Re: [Done] Cross on the screen
By the way, instead of "print screen", you can use "Display > Render to file" which is much more evolved and takes care of removing all non necessary items (such as the cross).
