Noise reduction
jonathanlepage
Noise reduction
Post by jonathanlepage »
Hi there,
Is there a step by step guide on how to reduce Point Cloud noise ?
is there a way to use this functionality using the command line ?
Re: Noise reduction
Sorry for the delay: I've just updated the 'Tools > Clean > Noise filter' page on the wiki:
http://www.cloudcompare.org/doc/wiki/in ... ise_filter
And you can't use it in command line mode yet.
jonathanlepage
Re: Noise reduction
Thanks!
I found a workaround using the command line as follow :
cloudcompare -o Test1.e57 -MERGE_CLOUDS -C_EXPORT_FMT E57 -FILTER_SF 0.05 0.980 -DENSITY 0.01 -TYPE KNN -FILTER_SF 10 MAX
-FILTER_SF removes very low and very high intensity (which are usually off using our scanner)
-DENSITY 0.01 -TYPE KNN -FILTER_SF 10 MAX I use this density calculator then filter to reduce noise level.
Would be nice if the command line would have an option to only save when every operation is finished. I have fairly huge Clouds, it fills my HDD very quickly.
Re: Noise reduction
Oups, the command line was not 100% up-to-date! (now it is ;).
There's a '-AUTO_SAVE OFF' command that you can set at the beginning of your command line. Then you have to manually call '-SAVE_CLOUDS' or '-SAVE_MESHES' at the end of your command line.
jonathanlepage
Re: Noise reduction
Great Thanks!
Any plans to add PCL commands in the command line?
Re: Noise reduction
For now there's no mechanism to call a plugin from the command line...
Mertikas
Re: Noise reduction
Post by Mertikas »
Hey there,
Can i find somewhere what is the algorithm that this tool uses, for reducing noise?
Thanks a lot!
Re: Noise reduction
As explains on the wiki page:
This algorithm locally fits a plane (around each point of the cloud) then removes the point if it's too far away from the fitted plane. This filter can be basically considered as a low pass filter.
