Command Line - Del Scalar Fields - Add Height Ramp
21nds
Post by 21nds »
Is it possible, from the command line to:
1. Delete all scalar fields
2. use Edit->Colors->Height Ramp->Banding->Frequency 20->Direction Z
Thanks.
Re: Command Line - Del Scalar Fields - Add Height Ramp
Nope ;)
I'll add this to the TODO list (but while the first one is trivial, the second might take more time...).
Okay it's done (two new options '-REMOVE_ALL_SFS' and 'CBANDING').
It will be available in the next release (or you can compile the code right now).
