How To Run Complete Qcanpo in Cloud Compare
All about Mac OS portage
ahmadshabbir735
Post by ahmadshabbir735 »
Hi .
i upload 2 sample in CC and Run Qcanupo from plugin and Its Gives Me a .prm file. But what Next ?
Because i also test Canupo Using command line The End Result is .las (Result.las file) But using canupo in Cloud compare I Don't know What to do after Saving .prm file ? How We can Generate Resultant file (Result.las)
Any Document How To run Q canupo Completely in Cloud Compare??
Re: How To Run Complete Qcanpo in Cloud Compare
After generating a classifier file (or use one provided by Dimtri Lague on his webpage for instance), you have to apply it an a real cloud.
Follow the documentation here: http://www.cloudcompare.org/doc/wiki/in ... O_(plugin)
asmaloney
Post by asmaloney »
Since this is posted in the macOS section I should point out that the CANUPO plugin is not available in the macOS version.
