Add 3d points in Point Cloud
doraCC18
Post by doraCC18 »
I have developed a program in Matlab that unwraps cylindrical surfaces using only a dense point cloud. I have a problem though because the point cloud I want to unwrap represents a cylindrical roof and it has "holes" no points in the areas of the roof windows. I would like to add points in these areas with white color and I was wondering if there is any automatic way in CloudCompare so that I can add points every 3mm in order to fill the gaps that the windows have created.
Thank you in advance
Theodora
Re: Add 3d points in Point Cloud
Not really.
You can still cut out the points on the border of the holes, either fit a plane (if they are on a flat surface) or create a 2.5D mesh (with Delaunay) and eventually sample points on the generated plane/mesh.
