I have produced a Project in which I have Registered a couple of Scans, Registered "External References," produced a Project Point Cloud, and then assigned a Clipping Box. From that Clipping Box I export an .e57.
This is two Point Clouds in .e57, of a back yard ("shot" several months apart). They do appear to have registered quite satisfactorily, but as you can see, the scans are decimated. I have no idea what might be causing the voids.
The same problem occurs whether or not I export from the Clipping Boxes or via File>Scan Project>Export Project Point Cloud. It occurs with at least .e57 and .pts exports.
Any ideas as to what voodoo this might be?! TIA!
