Thanks a lot for your last answer.
Now I Found a new Bug.
I'm doing the same work with storage tank, but now when i generated the 2d distance map, I¡m having problem with the DXF export! Problem that I didn't have in older version, and in 2.91 version is supposed to correct it =(
I also try the 2.10 alpha, but the problem persist.
PLeaseeee, what can i do?
Y try to open the file in different programs, the only one that open it was a global mapper, but i lost all the layers.
Greetings!
Hope you can help me.
Diego.
Surface of Revolution Analysis NEW bug
- 03 Verticalidad.rar
- (368.87 KiB) Downloaded 280 times
Re: Surface of Revolution Analysis NEW bug
You were right! The bug was fixed in the DXF I/O filter (to save DXF files in CC). But not in the SRA plugin :(
It should be fixed now. Can you try with the latest online version?
NOUP =(
I downloaded the last 2.9.1 version! and still not working!
Or do you mean the 2.10 alpha?
I had to downgrade to 2.8.1 for continue working! luckily I still had it saved
Regards!
Regards!
- prueba.rar
- (56.8 KiB) Downloaded 270 times
Yes, try the alpha (it's the only one that is not fixed and evolves constantly).
Daniel,
Thanks a lot for your help, time and of course for the quality of this amazing software!! and obviously for your amazing response speed :D
Now works fine :D
regards Daniel!!
Now works fine :D
regards Daniel!!
