Point Classifications...
wojocad
Post by wojocad »
I've been at this about a day... I've opened some LAS files in Cloud Compare and I'm looking around pressing buttons to see what they do. I managed to find the Statistical Outlier Filter. It deleted a bunch of points and I noticed that I could now see buildings among the trees better. Is there a way to turn off certain LIDAR point classifications in the viewer? I'd like to turn off the trees completely.
Thanks.
Re: Point Classifications...
If you activate the 'classification' scalar field, then you can either use the Scalar Field display parameters to hide some ponts with particular values (with the 'min' and 'max displayed' values, as well as the option to 'hide NaN/out of range values'), or maybe more easily to create a new subset of points with the right values (with 'Edit > Scalar fields > Filter by value').
