How to Sleep in Plugin?
CCNewbieL6
Post by CCNewbieL6 »
Hello!
When I try to Sleep(10000) in my plugin, a plugin with GUI, the plugin crushed.
The Sleep() is to wait a thread, which is doing tasks.
#include <thread>
#include <windows.h>
void CCLivoxLOAMDlg::on_StartButton_clicked() {
	//std::this_thread::sleep_for(std::chrono::seconds(100));   // crush here
	Sleep(10000);   // here too
Whether I need to create a new thread to run the Sleep() code?
Thanks!
Re: How to Sleep in Plugin?
With Qt you wouldn't sleep in the main thread (as it blocks everything). The best would be to have a QTimer (single shot) that would trigger a 'slot' function after 10000 ms for instance (see QTimer::timeout - https://doc.qt.io/qt-5/qtimer.html#timeout)
CCNewbieL6
Thank you, daniel!
CCNewbieL6
I solved this problem by creating a thread.
To create a thread to do something like sleep().
This way:
#include <thread>
void Scanner(int a){
	Sleep(100);
std::thread *lidarThread;
//To run Scanner(1) in a thread;
lidarThread = new std::thread(Scanner, 1);
