PablerasBCN
Posts: 323 Joined: Sat Jan 20, 2018 1:57 pm
Post
by PablerasBCN » Thu Nov 11, 2021 9:33 am
Please add option such as when meshing where max edge lenght is optional.
This way I could get rid of this horrible polygon like color areas when rasterizing with interpolation.
cheers
Posts: 8183 Joined: Wed Oct 13, 2010 7:34 am
Post
by daniel » Fri Nov 12, 2021 10:37 am
Ah, that's actually a good idea
Post
by daniel » Fri Nov 12, 2021 12:12 pm
I've added it in the latest 2.12.beta version (it's also possible to set this via the command line).
And I also added the option to the 2.5D Volume calculation tool (but not via the command line for this one).
PablerasBCN
Post
by PablerasBCN » Sun Nov 28, 2021 10:49 pm
Thank you so much Daniel,
It's working, but there may be something off.
The magnitude of the "Max edge lenght" parameter may be 1/100 by any chance? or raster space units are non related to work space units?
I was noticing imputing "2" that it was behaving as non interpolated leaving a shitton of gaps, while entering 20 and 200 afterwards, with 200 in particular I was getting same "meshing" as when inputing "2" when generating the 2.5 mesh.
Post
by daniel » Mon Nov 29, 2021 8:17 pm
I think it may depends on your grid step? Since with a grid step of 1, most of the triangle will have either edges of length 1 or sqrt(2)...
Anyway, normally the edge length should be expressed in the same units as the grid step or the point coordinates.
