Faro plugin on Mac
Loic3913
Faro plugin on Mac
Post by Loic3913 »
I'm using CC to segment laser scans with a polyline defined in CC (.bin). The scans come from a laser scanner Faro and the format is FLS. I'm using a Windows computer and I can load the scans in format .fls in CC with the Faro plugin, however given the high number of scans (about 2500 scans) and their size (400 Mo, 60 millions of points), it is quite long to load a few scans in CC and to apply a segmentation and to save it after. So to be faster I would like to work at the same time with a Mac that I have, I tried to load a scan in format .fls in CC on Mac (CC version 2.11.1) but it doesn't work, is there any way to add the Faro plugin on Mac ? And is there any way on Windows that could allows to load the scans and apply a segmentation in a faster way ?
Thank you for your help
Re: Faro plugin on Mac
I don't believe the Faro LS plugin is available on macOS?
And on Windows, you maybe be able to use the command line mode to automate the process? (https://www.cloudcompare.org/doc/wiki/i ... _line_mode)
