Command line flip triangles for mesh
charmainet
Post by charmainet »
Is there a command to flip triangles? (in app: edit/mesh/flip triangles)
Thanks.
Re: Command line flip triangles for mesh
Probably not... This would have to be added (I can add this to the TODO list).
Well, as it was as long to develop than to edit the TODO list, I added it ;)
It will be the -FLIP_TRI option.
You can test it with the first 2.13.alpha version: https://www.cloudcompare.org/release/Cl ... up_x64.exe
I'll wait for your feedback.
charmainet
HI Daniel,
It worked perfectly! Thank you
