Comand line saved clouds not readble in CC
pmr
Post by pmr »
I'm using command lines for working with pointclouds (subsampling, filtering, c2c_dist) and showing the result in CCViewer. Clouds can be imported in .bin or .txt without problems, but after filtering, I saved the resulting cloud in .bin and tried also in .txt. The problem is, the saved .bin clouds can not be opened in CC for further processing (neither inline nor in the normal interface). In the normal interface a message shows saying they are corrupted. Nevertheless, CCViewer can import them perfectly. As for .txt format, neither CCViewer nor CC can import the clouds. A further processing with inline commands is not possible.
Can You help me? My version is 2.9.1 (64 bit).
Best regards
Paula
Re: Comand line saved clouds not readble in CC
Hum, that's strange, but with such an old version, it's hard to help you!
Can't you try with the 2.12.1 version?
