process dialog in separate thread
PablerasBCN
Post by PablerasBCN »
Hi.
Sometimes I screw with the values or I get to optimistic of the power I've available and I get trapped in a ridiculously slow moving porgress bar. If attemp to cancel CC kinda stalls or stalls till next refresh but the click on cancel but is not recorded so unless you hit and have the luck to click on the exact moment the ui refreshes there is no mean to cancel an slow process. Hence request would be to be able to cancel processess no matter how hard CPU is trying.
Re: process dialog in separate thread
That's only possible if not all the cores are used at the same time. Some tools let you define the number of threads. In which case, don't hesitate to reduce it. Otherwise...
PablerasBCN
Good to know!, tx
