Animation mode is not supported (no FFMPEG support)
All about Mac OS portage
kungphil
Post by kungphil »
Hi there
I would like to create animations in CloudCompare however I get the following error message.
I have installed FFMPEG with homebrew and it is located at /opt/homebrew/bin/ffmpeg. I did this before installing CloudCompare
CloudCompare version 2.12.3
FFMPEG version 5.1.1
macOS 12.4
Any solution greatly appreciated!
Phil
Re: Animation mode is not supported (no FFMPEG support)
Ah sadly you would also need to compile CC with ffmpeg support! This is not done in the default macOS version because Thomas didn't manage so far to make it work... See https://github.com/CloudCompare/CloudCo ... ssues/1671
