Export of points to txt, dwg
p..
Post by p.. »
I have a question, is it possible in cloud compare to outline a broken line of a cloud of points along one of the X, Y, Z axes and then the program to mark the break points?
How can I export the points that I marked on the point cloud to txt or dwg,dxf format?
Thank you for your answer.
Re: Export of points to txt, dwg
Sorry, I'm not sure to understand...
p..
Post by p.. »
I want to select points on the point cloud using the "Point list picking" function and then export to dxf
Ah, then you have to use the 'Point list picking' tool, export the picked points as a new cloud (click on the arrow next to the floppy icon, and select 'new cloud'), and eventually select the exported cloud and save it as DXF.
