Bug - merge in command line mode
subo3
Post by subo3 »
It seems to me there is a bug in the current 2.13 beta (7. Feb).
When merging point clouds in the command line mode, the size increases, just as the number of points. But only the points of the first point cloud are visible. Same command in 2.12 and it works fine.
Command:
cloudcompare -SILENT -AUTO_SAVE OFF -C_EXPORT_FMT E57 -O "[pc1.e57]" -O "[pc2.e57]" -MERGE_CLOUDS -SAVE_CLOUDS FILE "path/to/merged_cloud.e57"
Re: Bug - merge in command line mode
Yes, it's a bug with E57 files saving in fact. It was introduced on the 27th of January... See https://github.com/CloudCompare/CloudCo ... ssues/1959
This is now fixed with the latest 2.13.beta version (10th of Feb).
