CC Crush after using the "creates a 2d deviation map" tool
Getarq
Post by Getarq »
Everytime I use the "creates a 2d deviation map radial distance"tool, CC crush and i lost the work!
I just have to save everything before and then use the tool, because it'll crush.
Diego Ramirez
Architect
www.getarq.com
Re: CC Crush after using the "creates a 2d deviation map" tool
Which version are you using?
If it's not the latest 2.13 version, can you try with this new version?
If it is the latest 2.13 version, can you share your data with us? (save all entities as a BIN file and send it to admin@cloudcompare.org)
Getarq
Post by Getarq »
Sorry Daniel, I didn't saw your answer!
Right now I just installed the 2.13.1, and I was using the 2.13 before.
I'll check with this new version and I'll be back!
Thanks.
Diego.
Diego Ramirez
Architect
www.getarq.com
