Unable to use command line mode in v2.13
SDADEEC
Post by SDADEEC »
I installed the v2.13 version from the website instruction via
flatpak install flathub org.cloudcompare.CloudCompare
on Ubuntu 20.04. But there is no bash command of cloudcompare. Is the command line mode still supported in v2.13?
Thank you!
Re: Unable to use command line mode in v2.13
Yes it is.
SDADEEC
Post by SDADEEC »
Do I need to set up anything to enable the command line mode?
Nope. Just call it in a terminal (CloudCompare -O myfile.bin ...)
