[FIXED] Crashing when doing Raterize grid
cloudmaster
Post by cloudmaster »
I have open an STL file to CC. I make it first to a cloud in Edit > Octree > Resample.
Then I want to make Raterize points - but as soon I click OK to make the points, then CC is crashing??
Why is it doing that? Hope there is a solution or a workaround to this issue!
Re: Crashing when doing Raterize grid
Hum, that's strange.
To isolate the issue, can you save the cloud (in BIN format for instance), close CC then re-open the cloud (not the STL) and try Rasterize again? If CC is still crashing, then send me the BIN cloud (email: cloudcompare [at] danielgm.net).
Otheriwse it might come from the STL importer (in which case I'm more interested in the STL file).
P.S.: it may be better to use the "Edit > Mesh > Sample points" to transform a mesh into a point cloud.
cloudmaster
OK, I have send you the files!
Looking forward to hear back from you...
Forgot to update this thread: the issue has been fixed in the 2.5.4 version.
