CloudCompare 3D entities
Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
ccGLMatrixTpl< T > Class Template Reference
A 4x4 'transformation' matrix (column major order) More...
#include <ccGLMatrixTpl.h>
Inheritance diagram for ccGLMatrixTpl< T >:
Inheritance graph
Collaboration diagram for ccGLMatrixTpl< T >:
 ccGLMatrixTpl ()
 Default constructor. More...
 ccGLMatrixTpl (const ccGLMatrixTpl< T > &mat)
 Copy constructor.
 ccGLMatrixTpl (const float *mat16f)
 Constructor from a float GL matrix array. More...
 ccGLMatrixTpl (const double *mat16d)
 Constructor from a double GL matrix array. More...
 ccGLMatrixTpl (const Vector3Tpl< T > &X, const Vector3Tpl< T > &Y, const Vector3Tpl< T > &Z, const Vector3Tpl< T > &Tr)
 Constructor from 4 columns (X,Y,Z,T) More...
QString toString (int precision=12, QChar separator=' ') const
 Returns matrix as a string. More...
virtual bool toAsciiFile (QString filename, int precision=12) const
 Saves matrix to an ASCII file. More...
virtual bool fromAsciiFile (QString filename)
 Loads matrix from an ASCII file. More...
ccGLMatrixTpl< T > xRotation () const
 Returns the rotation component around X only.
ccGLMatrixTpl< T > yRotation () const
 Returns the rotation component around Y only.
ccGLMatrixTpl< T > zRotation () const
 Returns the rotation component around Z only.
virtual void toZero ()
 Clears matrix. More...
virtual void toIdentity ()
 Sets matrix to identity.
void clearTranslation ()
 Clears translation. More...
void initFromParameters (T alpha_rad, const Vector3Tpl< T > &axis3D, const Vector3Tpl< T > &t3D)
 Inits transformation from a rotation axis, an angle and a translation. More...
void initFromParameters (T phi_rad, T theta_rad, T psi_rad, const Vector3Tpl< T > &t3D)
 Inits transformation from 3 rotation angles and a translation. More...
void getParameters (T &alpha_rad, Vector3Tpl< T > &axis3D, Vector3Tpl< T > &t3D) const
 Returns equivalent parameters: a rotation axis, an angle and a translation. More...
void getParameters (T &phi_rad, T &theta_rad, T &psi_rad, Vector3Tpl< T > &t3D) const
 Returns equivalent parameters: 3 rotation angles and a translation. More...
T * data ()
 Returns a pointer to internal data.
const T * data () const
 Returns a const pointer to internal data.
T * getTranslation ()
 Returns a pointer to internal translation. More...
const T * getTranslation () const
 Returns a const pointer to internal translation. More...
Vector3Tpl< T > getTranslationAsVec3D () const
 Returns a copy of the translation as a CCVector3. More...
void setTranslation (const Vector3Tpl< float > &Tr)
 Sets translation (float version) More...
void setTranslation (const Vector3Tpl< double > &Tr)
 Sets translation (double version) More...
void setTranslation (const float Tr[3])
 Sets translation from a float array. More...
void setTranslation (const double Tr[3])
 Sets translation from a double array. More...
T * getColumn (unsigned index)
 Returns a pointer to a given column. More...
const T * getColumn (unsigned index) const
 Returns a const pointer to a given column. More...
Vector3Tpl< T > getColumnAsVec3D (unsigned index) const
 Returns a copy of a given column as a CCVector3. More...
void setColumn (unsigned index, const Vector3Tpl< T > &v)
 Sets the content of a given column. More...
void setColumn (unsigned index, const Tuple4Tpl< T > &v)
ccGLMatrixTpl< T > operator* (const ccGLMatrixTpl< T > &mat) const
 Multiplication by a matrix operator.
Vector3Tpl< float > operator* (const Vector3Tpl< float > &vec) const
 Multiplication by a vector operator (float version)
Vector3Tpl< double > operator* (const Vector3Tpl< double > &vec) const
 Multiplication by a vector operator (double version)
Tuple4Tpl< float > operator* (const Tuple4Tpl< float > &vec) const
 Multiplication by a 4D vector operator (float version)
Tuple4Tpl< double > operator* (const Tuple4Tpl< double > &vec) const
 Multiplication by a 4D vector operator (double version)
ccGLMatrixTpl< T > & operator+= (const ccGLMatrixTpl< T > &mat)
 (in place) Addition operator
ccGLMatrixTpl< T > & operator-= (const ccGLMatrixTpl< T > &mat)
 (in place) Difference operator
ccGLMatrixTpl< T > & operator*= (const ccGLMatrixTpl< T > &mat)
 (in place) Multiplication operator
ccGLMatrixTpl< T > & operator+= (const Vector3Tpl< float > &Tr)
 (in place) Forward translation operator (float version)
ccGLMatrixTpl< T > & operator+= (const Vector3Tpl< double > &Tr)
 (in place) Forward translation operator (double version)
ccGLMatrixTpl< T > & operator-= (const Vector3Tpl< float > &Tr)
 (in place) Backward translation operator (float version)
ccGLMatrixTpl< T > & operator-= (const Vector3Tpl< double > &Tr)
 (in place) Backward translation operator (double version)
operator() (unsigned row, unsigned col) const
 Returns the value at a given position.
void apply (Vector3Tpl< float > &vec) const
 Applies transformation to a 3D vector (in place) - float version. More...
void apply (Vector3Tpl< double > &vec) const
 Applies transformation to a 3D vector (in place) - double version. More...
void apply (Tuple4Tpl< float > &vec) const
 Applies transformation to a 4D vector (in place) - float version. More...
void apply (Tuple4Tpl< double > &vec) const
float applyX (const Vector3Tpl< float > &vec) const
 Get the resulting transformation along X dimension (float version)
double applyX (const Vector3Tpl< double > &vec) const
 Get the resulting transformation along X dimension (double version)
float applyY (const Vector3Tpl< float > &vec) const
 Get the resulting transformation along Y dimension (float version)
double applyY (const Vector3Tpl< double > &vec) const
 Get the resulting transformation along Y dimension (double version)
float applyZ (const Vector3Tpl< float > &vec) const
 Get the resulting transformation along Z dimension (float version)
double applyZ (const Vector3Tpl< double > &vec) const
 Get the resulting transformation along Z dimension (double version)
float applyX (const Tuple4Tpl< float > &vec) const
double applyX (const Tuple4Tpl< double > &vec) const
float applyY (const Tuple4Tpl< float > &vec) const
double applyY (const Tuple4Tpl< double > &vec) const
float applyZ (const Tuple4Tpl< float > &vec) const
double applyZ (const Tuple4Tpl< double > &vec) const
float applyW (const Tuple4Tpl< float > &vec) const
 Get the resulting transformation along the 4th dimension (float version)
double applyW (const Tuple4Tpl< double > &vec) const
 Get the resulting transformation along the 4th dimension (double version)
void applyRotation (Vector3Tpl< float > &vec) const
 Applies rotation only to a 3D vector (in place) - float version. More...
void applyRotation (Vector3Tpl< double > &vec) const
 Applies rotation only to a 3D vector (in place) - double version. More...
void applyRotation (float vec[3]) const
void applyRotation (double vec[3]) const
void shiftRotationCenter (const Vector3Tpl< T > &vec)
 Shifts rotation center. More...
void transpose ()
 Transposes matrix (in place)
ccGLMatrixTpl< T > transposed () const
 Returns transposed matrix.
void invert ()
 Inverts transformation.
ccGLMatrixTpl< T > inverse () const
 Returns inverse transformation.
void scaleRotation (T coef)
 Scales the rotation part of the matrix. More...
void scaleRow (unsigned rowIndex, T coef)
 Scales one row of the matrix. More...
void scaleColumn (unsigned colIndex, T coef)
 Scales one column of the matrix. More...
 Destructor.
static ccGLMatrixTpl Interpolate (T coef, const ccGLMatrixTpl< T > &glMat1, const ccGLMatrixTpl< T > &glMat2)
 Interpolates two matrices at relative position 'coef'. More...
static ccGLMatrixTpl< T > FromToRotation (const Vector3Tpl< T > &from, const Vector3Tpl< T > &to)
 Creates a transformation matrix that rotates a vector to another. More...
template<class Tq >
static ccGLMatrixTpl< T > FromQuaternion (const Tq q[])
 Converts a quaternion to a rotation matrix. More...
static ccGLMatrixTpl< T > FromViewDirAndUpDir (const Vector3Tpl< T > &forward, const Vector3Tpl< T > &up)
 Generates a 'viewing' matrix from a looking vector and a 'up' direction. More...
static ccGLMatrixTpl< T > FromString (const QString &matText, bool &success)
 Converts a 'text' matrix to a ccGLMatrix. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
void internalRescale ()
 Transfers the homogenous coordinate (scale) to the whole matrix.
m_mat [OPENGL_MATRIX_SIZE]
 Internal 4x4 GL-style matrix data.
Additional Inherited Members
template<typename T>
class ccGLMatrixTpl< T >
Transformation (M) is composed by a rotation (R) and a translation (T): M*X = R*X + T
◆ ccGLMatrixTpl() [1/4]
template<typename T >
ccGLMatrixTpl< T >::ccGLMatrixTpl ( )
inline
Matrix is set to identity (see toIdentity) by default.
◆ ccGLMatrixTpl() [2/4]
ccGLMatrixTpl< T >::ccGLMatrixTpl ( const float *  mat16f)
inlineexplicit
mat16fa 16 elements array (column major order)
◆ ccGLMatrixTpl() [3/4]
ccGLMatrixTpl< T >::ccGLMatrixTpl ( const double *  mat16d)
inlineexplicit
Warning
Will implicitly cast the elements to float!
mat16da 16 elements array (column major order)
◆ ccGLMatrixTpl() [4/4]
ccGLMatrixTpl< T >::ccGLMatrixTpl ( const Vector3Tpl< T > &  X,
const Vector3Tpl< T > &  Y,
const Vector3Tpl< T > &  Z,
const Vector3Tpl< T > &  Tr
inline
X3 first elements of the 1st column (last one is 0)
Y3 first elements of the 2nd column (last one is 0)
Z3 first elements of the 3rd column (last one is 0)
Tr3 first elements of the last column (last one is 1)
Member Function Documentation
◆ apply() [1/4]
void ccGLMatrixTpl< T >::apply ( Tuple4Tpl< double > &  vec) const
inline
Input vector is directly modified after calling this method
◆ apply() [2/4]
void ccGLMatrixTpl< T >::apply ( Tuple4Tpl< float > &  vec) const
inline
◆ apply() [3/4]
void ccGLMatrixTpl< T >::apply ( Vector3Tpl< double > &  vec) const
inline
◆ apply() [4/4]
void ccGLMatrixTpl< T >::apply ( Vector3Tpl< float > &  vec) const
inline
◆ applyRotation() [1/4]
void ccGLMatrixTpl< T >::applyRotation ( double  vec[3]) const
inline
Input array is directly modified after calling this method
◆ applyRotation() [2/4]
void ccGLMatrixTpl< T >::applyRotation ( float  vec[3]) const
inline
◆ applyRotation() [3/4]
void ccGLMatrixTpl< T >::applyRotation ( Vector3Tpl< double > &  vec) const
inline
◆ applyRotation() [4/4]
void ccGLMatrixTpl< T >::applyRotation ( Vector3Tpl< float > &  vec) const
inline
◆ clearTranslation()
void ccGLMatrixTpl< T >::clearTranslation ( )
inline
Clears translation.
Translation is set to (0,0,0).
◆ fromAsciiFile()
virtual bool ccGLMatrixTpl< T >::fromAsciiFile ( QString  filename)
inlinevirtual
filenameinput file name
Reimplemented in ccIndexedTransformation.
◆ fromFile()
bool ccGLMatrixTpl< T >::fromFile ( QFile &  in,
short  dataVersion,
int  flags,
LoadedIDMap oldToNewIDMap
inlineoverridevirtual
Loads data from binary stream.
ininput file (already opened)
dataVersionfile version
Returns
success
◆ FromQuaternion()
template<class Tq >
static ccGLMatrixTpl< T > ccGLMatrixTpl< T >::FromQuaternion ( const Tq  q[])
inlinestatic
qquaternion (4 values: w,x,y,z)
Returns
corresponding rotation matrix
◆ FromString()
static ccGLMatrixTpl< T > ccGLMatrixTpl< T >::FromString ( const QString &  matText,
bool &  success
inlinestatic
[in]matTextmatrix text
[out]successwhether input matrix text is valid or not
◆ FromToRotation()
static ccGLMatrixTpl< T > ccGLMatrixTpl< T >::FromToRotation ( const Vector3Tpl< T > &  from,
const Vector3Tpl< T > &  to
inlinestatic
Adapted from "Efficiently Building a Matrix to Rotate One Vector to Another" By Tomas Möller, John Hughes, Journal of Graphics Tools, 4(4):1-4, 1999
fromnormalized non-zero source vector
tonormalized non-zero destination vector
◆ FromViewDirAndUpDir()
static ccGLMatrixTpl< T > ccGLMatrixTpl< T >::FromViewDirAndUpDir ( const Vector3Tpl< T > &  forward,
const Vector3Tpl< T > &  up
inlinestatic
Warning
No translation is applied (pure rotation matrix)
forwardforward 'view' vector
upup vector
Returns
◆ getColumn() [1/2]
T * ccGLMatrixTpl< T >::getColumn ( unsigned  index)
inline
indexcolumn index (between 0 and 3)
Returns
pointer to the first element of the corresponding column
◆ getColumn() [2/2]
const T * ccGLMatrixTpl< T >::getColumn ( unsigned  index) const
inline
Returns
◆ getColumnAsVec3D()
Vector3Tpl< T > ccGLMatrixTpl< T >::getColumnAsVec3D ( unsigned  index) const
inline
4th value is ignored.
Returns
copy of the three first elements of the corresponding column
◆ getParameters() [1/2]
void ccGLMatrixTpl< T >::getParameters ( T &  alpha_rad,
Vector3Tpl< T > &  axis3D,
Vector3Tpl< T > &  t3D
) const
inline
[out]alpha_radrotation angle in radians (in [0;pi])
[out]axis3Dunit rotation axis
[out]t3Dtranslation
◆ getParameters() [2/2]
void ccGLMatrixTpl< T >::getParameters ( T &  phi_rad,
T &  theta_rad,
T &  psi_rad,
) const
inline
See http://en.wikipedia.org/wiki/Euler_angles (Tait-Bryan Z1Y2X3)
[out]phi_radPhi angle (in radians)
[out]theta_radTheta angle (in radians)
[out]psi_radPsi angle (in radians)
[out]t3Dtranslation
◆ getTranslation() [1/2]
T * ccGLMatrixTpl< T >::getTranslation ( )
inline
Translation corresponds to the beginning of the third column of the matrix.
◆ getTranslation() [2/2]
const T * ccGLMatrixTpl< T >::getTranslation ( ) const
inline
◆ getTranslationAsVec3D()
Vector3Tpl< T > ccGLMatrixTpl< T >::getTranslationAsVec3D ( ) const
inline
Returns
translation vector
◆ initFromParameters() [1/2]
void ccGLMatrixTpl< T >::initFromParameters ( alpha_rad,
const Vector3Tpl< T > &  axis3D,
const Vector3Tpl< T > &  t3D
inline
[in]alpha_radrotation angle (in radians)
[in]axis3Drotation axis
[in]t3Dtranslation
◆ initFromParameters() [2/2]
void ccGLMatrixTpl< T >::initFromParameters ( phi_rad,
theta_rad,
psi_rad,
inline
[in]phi_radPhi angle (in radians)
[in]theta_radTheta angle (in radians)
[in]psi_radPsi angle (in radians)
[in]t3Dtranslation
◆ Interpolate()
static ccGLMatrixTpl ccGLMatrixTpl< T >::Interpolate ( coef,
const ccGLMatrixTpl< T > &  glMat1,
const ccGLMatrixTpl< T > &  glMat2
inlinestatic
coefinterpolation position (should be between 0 and 1).
glMat1'left' matrix
glMat2'right' matrix
◆ isSerializable()
bool ccGLMatrixTpl< T >::isSerializable ( ) const
◆ scaleColumn()
void ccGLMatrixTpl< T >::scaleColumn ( unsigned  colIndex,
coef
inline
Warning
The last row is never scaled
colIndexcolumn index (0-3)
coefscaling coef.
◆ scaleRotation()
void ccGLMatrixTpl< T >::scaleRotation ( coef)
inline
coefscaling coef.
◆ scaleRow()
void ccGLMatrixTpl< T >::scaleRow ( unsigned  rowIndex,
coef
inline
rowIndextow index (0-3)
coefscaling coef.
◆ setColumn() [1/2]
void ccGLMatrixTpl< T >::setColumn ( unsigned  index,
const Tuple4Tpl< T > &  v
inline
vnew column values
◆ setColumn() [2/2]
const Vector3Tpl< T > &  v
inline
vnew column values
◆ setTranslation() [1/4]
void ccGLMatrixTpl< T >::setTranslation ( const double  Tr[3])
inline
Tr3D vector as a double array
◆ setTranslation() [2/4]
void ccGLMatrixTpl< T >::setTranslation ( const float  Tr[3])
inline
Tr3D vector as a float array
◆ setTranslation() [3/4]
void ccGLMatrixTpl< T >::setTranslation ( const Vector3Tpl< double > &  Tr)
inline
Tr3D vector
◆ setTranslation() [4/4]
void ccGLMatrixTpl< T >::setTranslation ( const Vector3Tpl< float > &  Tr)
inline
Tr3D vector
◆ shiftRotationCenter()
void ccGLMatrixTpl< T >::shiftRotationCenter ( const Vector3Tpl< T > &  vec)
inline
Warning, this method only applies a shift (i.e. relatively to the current rotation center). This is not a way to set an absolute rotation center 'directly'.
◆ toAsciiFile()
virtual bool ccGLMatrixTpl< T >::toAsciiFile ( QString  filename,
int  precision = 12
) const
inlinevirtual
filenameoutput file name
precisionoutput digits precision
◆ toFile()
bool ccGLMatrixTpl< T >::toFile ( QFile &  out) const
Saves data to binary stream.
outoutput file (already opened)
Returns
success
◆ toString()
QString ccGLMatrixTpl< T >::toString ( int  precision = 12,
QChar  separator = ' '
) const
inline
precisionnumerical precision
separatorseparator
Returns
string
◆ toZero()
virtual void ccGLMatrixTpl< T >::toZero ( )
inlinevirtual
Clears matrix.
Matrix is set to 0.
