Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
ccNormalVectors Class Reference
Compressed normal vectors handler. More...
#include <ccNormalVectors.h>
Collaboration diagram for ccNormalVectors:
const CCVector3 & getNormal (unsigned normIndex) const
 Returns the precomputed normal corresponding to a given compressed index.
virtual ~ccNormalVectors ()
 Default destructor.
bool enableNormalHSVColorsArray ()
 Allocates normal HSV colors array. More...
const colorType * getNormalHSVColor (unsigned index) const
 Returns the HSV color equivalent to a given compressed normal index.
const colorType * getNormalHSVColorArray () const
 Returns the HSV color array.
static ccNormalVectorsGetUniqueInstance ()
 Returns unique instance.
static void ReleaseUniqueInstance ()
 Releases unique instance. More...
static unsigned GetNumberOfVectors ()
 Returns the number of compressed normal vectors.
static const CCVector3 & GetNormal (unsigned normIndex)
 Static access to ccNormalVectors::getNormal.
static void ComputeNormal (normsType normIndex, PointCoordinateType N[])
 Computes the normal corresponding to a given compressed index. More...
static normsType GetNormIndex (const PointCoordinateType N[])
 Returns the compressed index corresponding to a normal vector.
static normsType GetNormIndex (const CCVector3 &N)
 Returns the compressed index corresponding to a normal vector (shortcut)
static void InvertNormal (normsType &code)
 Inverts normal corresponding to a given compressed index. More...
static bool ComputeCloudNormals (ccGenericPointCloud *theCloud, NormsIndexesTableType &theNormsCodes, CC_LOCAL_MODEL_TYPES method, PointCoordinateType radius, int preferedOrientation=-1, CCLib::GenericProgressCallback *progressCb=0, CCLib::DgmOctree *inputOctree=0)
 Computes normal at each point of a given cloud. More...
static bool UpdateNormalOrientations (ccGenericPointCloud *theCloud, NormsIndexesTableType &theNormsCodes, int preferedOrientation)
 Updates normals orientation based on a preferred orientation. More...
static void ConvertNormalToStrikeAndDip (const CCVector3 &N, double &strike_deg, double &dip_deg)
 Converts a normal vector to geological 'strike & dip' parameters (N[dip]E - [strike]) More...
static void ConvertNormalToDipAndDipDir (const CCVector3 &N, PointCoordinateType &dip_deg, PointCoordinateType &dipDir_deg)
 Converts a normal vector to geological 'dip direction & dip' parameters. More...
static QString ConvertStrikeAndDipToString (double &strike_deg, double &dip_deg)
 Converts geological 'strike & dip' parameters (N[dip]E - [strike]) to a string. More...
static QString ConvertDipAndDipDirToString (PointCoordinateType dip_deg, PointCoordinateType dipDir_deg)
 Converts geological 'dip direction & dip' parameters to a string. More...
static void ConvertNormalToHSV (const CCVector3 &N, double &H, double &S, double &V)
 Converts a normal vector to HSV color space. More...
static void ConvertNormalToRGB (const CCVector3 &N, colorType &R, colorType &G, colorType &B)
 Converts a normal vector to RGB color space. More...
static void ConvertHSVToRGB (double H, double S, double V, colorType &R, colorType &G, colorType &B)
 Converts a HSV color to RGB color space. More...
static const unsigned NORMALS_QUANTIZE_LEVEL = 6
 Compressed normals quantization level (number of directions/bits: 2^(2*N+3))
 ccNormalVectors ()
 Default constructor. More...
bool init (unsigned quantizeLevel)
 Inits internal structures.
static void Quant_dequantize_normal (unsigned q, unsigned level, PointCoordinateType *res)
 Decompression algorithm. More...
static unsigned Quant_quantize_normal (const PointCoordinateType *n, unsigned level)
 Compression algorithm. More...
static bool ComputeNormsAtLevelWithHF (const CCLib::DgmOctree::octreeCell &cell, void **additionalParameters, CCLib::NormalizedProgress *nProgress=0)
 Cellular method for octree-based normal computation.
static bool ComputeNormsAtLevelWithLS (const CCLib::DgmOctree::octreeCell &cell, void **additionalParameters, CCLib::NormalizedProgress *nProgress=0)
static bool ComputeNormsAtLevelWithTri (const CCLib::DgmOctree::octreeCell &cell, void **additionalParameters, CCLib::NormalizedProgress *nProgress=0)
std::vector< CCVector3 > m_theNormalVectors
 Compressed normal vectors.
colorType * m_theNormalHSVColors
 'HSV' colors corresponding to each compressed normal index More...
ccNormalVectors::ccNormalVectors ( )
protected
Shouldn't be called directly. Use 'GetUniqueInstance' instead.
Member Function Documentation
bool ccNormalVectors::ComputeCloudNormals ( ccGenericPointCloud theCloud,
NormsIndexesTableType theNormsCodes,
int  preferedOrientation = -1,
CCLib::GenericProgressCallback *  progressCb = 0,
CCLib::DgmOctree *  inputOctree = 0
static
theCloudpoint cloud on which to process the normals.
theNormsCodesarray in which the normals indexes are stored
methodwhich kind of model to use for the computation (LS = plane, HF = quadratic Height Function, TRI = triangulation)
radiuslocal neighborhood radius (not necessary for TRI)
preferedOrientationspecifies a preferred orientation for normals (-1: no preferred orientation, 0:+X, 1:-X, 2:+Y, 3:-Y, 4:+Z, 5:-Z, 6:+Barycenter, 7:-Barycenter)
progressCbprogress bar
inputOctreeoctree associated with theCloud.
Returns
success
static void ccNormalVectors::ComputeNormal ( normsType  normIndex,
inlinestatic
Warning: slower than 'GetNormal' (but avoids computation of the whole table)
QString ccNormalVectors::ConvertDipAndDipDirToString ( PointCoordinateType  dip_deg,
static
[in]dip_degdip angle value (in degrees)
[in]dipDir_degdip direction value (in degrees)
Returns
formatted string "Dip direction: [dipDir] - Dip angle: [dip]"
static void ccNormalVectors::ConvertHSVToRGB ( double  H,
double  S,
double  V,
colorType &  R,
colorType &  G,
colorType &  B
static
H[out] hue [0;360[
S[out] saturation [0;1]
V[out] value [0;1]
R[out] red [0;MAX_COLOR_COMP]
G[out] green [0;MAX_COLOR_COMP]
B[out] blue [0;MAX_COLOR_COMP]
static void ccNormalVectors::ConvertNormalToDipAndDipDir ( const CCVector3 &  N,
PointCoordinateType &  dip_deg,
PointCoordinateType &  dipDir_deg
static
See http://en.wikipedia.org/wiki/Strike_and_dip The dip direction is the azimuth of the direction (in [0,360[). The dip is always in [0,90].
[in]Nnormal (should be normalized!)
[out]dip_degvalue (in degrees)
[out]dipDir_degdip direction value (in degrees)
static void ccNormalVectors::ConvertNormalToHSV ( const CCVector3 &  N,
double &  H,
double &  S,
double &  V
static
Uses 'strike & dip' parameters (H=strike, S=dip, V=constant)
N[in] normal (should be normalized!)
H[out] hue [0;360[
V[out] value [0;1]
static void ccNormalVectors::ConvertNormalToRGB ( const CCVector3 &  N,
colorType &  R,
colorType &  G,
colorType &  B
static
Uses 'ConvertNormalToHSV' then converts HSV to RGB.
void ccNormalVectors::ConvertNormalToStrikeAndDip ( const CCVector3 &  N,
double &  strike_deg,
double &  dip_deg
static
[out]strike_degstrike value (in degrees)
[out]dip_degdip value (in degrees)
Adapted from Andy Michael's 'stridip.c': Finds strike and dip of plane given normal vector having components n, e, and u output is in degrees north of east and then uses a right hand rule for the dip of the plane
QString ccNormalVectors::ConvertStrikeAndDipToString ( double &  strike_deg,
double &  dip_deg
static
[in]strike_degstrike value (in degrees)
[in]dip_degdip value (in degrees)
Returns
formatted string "N[strike]E - [dip]"
bool ccNormalVectors::enableNormalHSVColorsArray ( )
Mandatory for HSV color related methods (getNormalHSVColor, etc.)
void ccNormalVectors::InvertNormal ( normsType &  code)
static
Warning: compressed index is directly updated!
void ccNormalVectors::Quant_dequantize_normal ( unsigned  q,
unsigned  level,
PointCoordinateType *  res
staticprotected
special case for level = 0
recompute the box in the sector...
unsigned ccNormalVectors::Quant_quantize_normal ( const PointCoordinateType *  n,
unsigned  level
staticprotected
compute in which sector lie the elements
scale the sectored vector - early return for null vector
compute the box
then for each required level, quantize...
do not do the last operation ...
void ccNormalVectors::ReleaseUniqueInstance ( )
static
Call to this method is now optional.
bool ccNormalVectors::UpdateNormalOrientations ( ccGenericPointCloud theCloud,
static
preferedOrientationspecifies a preferred orientation for normals (0:+X, 1:-X, 2:+Y, 3:-Y, 4:+Z, 5:-Z, 6:+Barycenter, 7:-Barycenter, 8:+Zero, 9:-Zero)
Returns
success
Member Data Documentation
colorType* ccNormalVectors::m_theNormalHSVColors
protected
In fact, HSV color has already been converted to RGB here for faster display.
