Public Member Functions | Protected Member Functions | List of all members
DepthMapFileFilter Class Reference
Depth map I/O filter. More...
#include <DepthMapFileFilter.h>
Inheritance diagram for DepthMapFileFilter:
Inheritance graph
Collaboration diagram for DepthMapFileFilter:
CC_FILE_ERROR saveToOpenedFile (FILE *fp, ccGBLSensor *sensor)
Additional Inherited Members
Member Function Documentation
CC_FILE_ERROR DepthMapFileFilter::loadFile ( const char *  filename,
ccHObject &  container,
virtual
filenamefile to load
Returns
error
Implements FileIOFilter.
CC_FILE_ERROR DepthMapFileFilter::saveToFile ( ccHObject *  entity,
virtual
filenamefilename
Returns
error
