Plugins
Standard plugins
- [Windows, macOS, Linux] Compass Easy digitization of geological structures and structural traces on point clouds
- [Windows, macOS] Virtual Broom Efficient (road) scan cleaning
- [Windows, macOS] Hough Normals Normals computation
- [Windows, macOS] HPR Hidden Points Removal
- [Windows, Linux] PCL Interface for PCL library (normals computation, outliers removal, etc.)
- [Windows, macOS] PCV Ambient Occlusion for mesh or point cloud (output: per-point 'visibility' as a scalar field)
- [Windows, macOS, Linux] Poisson Surface Reconstruction Surface Mesh Reconstruction (for closed surfaces)
- [Windows, Linux] Ransac Shape Detection Automatic RANSAC Shape Detection
- [Windows, macOS] SRA Surface of Revolution Analysis (comparison between a point cloud and a surface of revolution)
- [Windows] CANUPO Point Cloud Classification with CANUPO
- [Windows] 3DMASC Advanced Point Cloud Classification with Multiple Attributes, Scales and Clouds
- [Windows, macOS, Linux] M3C2 Computation of robust signed distances between point clouds
- [Windows] Cork Mesh Boolean Operations (Constructive Solid Geometry) based on the Cork library
- [Windows] Mesh Boolean Mesh Boolean Operations (Constructive Solid Geometry) based on the libigl library
- [Windows, macOS] Animation Animation rendering plugin
- [Windows, macOS] Facets Structural geology plugin
- [Windows, macOS] CSF Automatic ground/non-ground classification algorithm based on Cloth Simulation
- [Windows] MPlane Normal distance measurements against a defined plane.
- [Windows] Colorimetric Segmenter Color-based segmentation of point clouds.
- [Windows] Masonry Segmentation segmentation of dense point clouds of masonry structures into their individual stones.
- [Windows, macOS] Cloud Layers Manual classification of a cloud
- [Windows, ?] TreeIso Individual-tree isolation (treeiso) from terrestrial laser scanning
- [Windows, linux] 3DFin 3D Forest Inventory
- [Windows, linux] VoxFall Non-Parametric Volumetric Change Detection for Rockfalls
Deprecated
- qKinect Acquisition of colored point clouds with a Kinect device
