Plugins
Revision as of 10:00, 26 March 2025 by Ioannis (talk | contribs) (→Standard plugins)
Standard plugins
  • [Windows] 3DMASC Advanced Point Cloud Classification with Multiple Attributes, Scales and Clouds
  • [Windows, ?] TreeIso Individual-tree isolation (treeiso) from terrestrial laser scanning
  • [Windows, linux] 3DFin 3D Forest Inventory
  • [Windows, Linux] VoxFall Non-Parametric Volumetric Change Detection for Rockfalls
Deprecated
OpenGL 'shaders' plugins
  • qEDL (Eye Dome Lighting)
