CloudCompare 3D entities
Classes | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
ccFastMarchingForNormsDirection Class Reference
Fast Marching algorithm for normals direction resolution. More...
#include <ccFastMarchingForNormsDirection.h>
Inheritance diagram for ccFastMarchingForNormsDirection:
Inheritance graph
Collaboration diagram for ccFastMarchingForNormsDirection:
Classes
class  DirectionCell
 A Fast Marching grid cell for normals direction resolution. More...
 ccFastMarchingForNormsDirection ()
 Default constructor.
int init (ccGenericPointCloud *cloud, NormsIndexesTableType *theNorms, ccOctree *theOctree, unsigned char gridLevel)
 Initializes the grid with a point cloud (and ist corresponding octree) More...
unsigned updateResolvedTable (ccGenericPointCloud *theCloud, std::vector< unsigned char > &resolved, NormsIndexesTableType *theNorms)
 Updates a list of point flags, indicating the points already processed. More...
int propagate () override
static int OrientNormals (ccPointCloud *theCloud, unsigned char octreeLevel, ccProgressDialog *progressCb=nullptr)
 Static entry point (helper)
float computeTCoefApprox (CCCoreLib::FastMarching::Cell *currentCell, CCCoreLib::FastMarching::Cell *neighbourCell) const override
int step () override
void initTrialCells () override
bool instantiateGrid (unsigned size) override
float computePropagationConfidence (DirectionCell *originCell, DirectionCell *destCell) const
 Computes relative 'confidence' between two cells (orientations) More...
void resolveCellOrientation (unsigned index)
 Resolves the direction of a given cell (once and for all)
Extends the FastMarching class.
Member Function Documentation
◆ computePropagationConfidence()
float ccFastMarchingForNormsDirection::computePropagationConfidence ( DirectionCell originCell,
DirectionCell destCell
) const
protected
Returns
confidence between 0 and 1
◆ init()
int ccFastMarchingForNormsDirection::init ( ccGenericPointCloud cloud,
NormsIndexesTableType theNorms,
ccOctree theOctree,
The points should be associated to an (active) scalar field. The Fast Marching grid will have the same dimensions as the input octree considered at a given level of subdivision.
cloudthe point cloud
theNormsthe normals array
theOctreethe associated octree
gridLevelthe level of subdivision
Returns
a negative value if something went wrong
◆ updateResolvedTable()
unsigned ccFastMarchingForNormsDirection::updateResolvedTable ( ccGenericPointCloud theCloud,
std::vector< unsigned char > &  resolved,
Returns
the number of resolved points
