CloudCompare 3D entities
Public Types | Public Member Functions | Static Public Member Functions | Public Attributes | List of all members
ccCameraSensor::BrownDistortionParameters Struct Reference
Brown's distortion model + Linear Disparity. More...
#include <ccCameraSensor.h>
Inheritance diagram for ccCameraSensor::BrownDistortionParameters:
Inheritance graph
Collaboration diagram for ccCameraSensor::BrownDistortionParameters:
Public Types
using Shared = QSharedPointer< BrownDistortionParameters >
 Shared pointer type.
- Public Types inherited from ccCameraSensor::LensDistortionParameters
using Shared = QSharedPointer< LensDistortionParameters >
 BrownDistortionParameters ()
 Default initializer.
DistortionModel getModel () const override
 Returns distortion model type. More...
- Public Member Functions inherited from ccCameraSensor::LensDistortionParameters
virtual ~LensDistortionParameters ()=default
 Virtual destructor.
virtual DistortionModel getModel () const =0
static void GetKinectDefaults (BrownDistortionParameters &params)
 Helper: initializes a IntrinsicParameters structure with the default Kinect parameters.
Public Attributes
float principalPointOffset [2]
float linearDisparityParams [2]
float K_BrownParams [3]
float P_BrownParams [2]
To know how to use K & P parameters, please read: "Decentering Distortion of Lenses", Duane C. Brown To know how to use the linearDisparityParams parameter (kinect attribute), please read: "Accuracy and Resolution of Kinect Depth Data for Indoor Mapping Applications", K. Khoshelham and S.O. Elberink
Member Function Documentation
◆ getModel()
DistortionModel ccCameraSensor::BrownDistortionParameters::getModel ( ) const
inlineoverridevirtual
Implements ccCameraSensor::LensDistortionParameters.
Member Data Documentation
◆ K_BrownParams
float ccCameraSensor::BrownDistortionParameters::K_BrownParams[3]
radial parameters Brown's distortion model
◆ linearDisparityParams
float ccCameraSensor::BrownDistortionParameters::linearDisparityParams[2]
contains A and B where : 1/Z = A*d' + B (with Z=depth and d'=normalized disparity)
◆ P_BrownParams
float ccCameraSensor::BrownDistortionParameters::P_BrownParams[2]
tangential parameters Brown's distortion model
◆ principalPointOffset
float ccCameraSensor::BrownDistortionParameters::principalPointOffset[2]
offset of the principal point (in meters)
The documentation for this struct was generated from the following files:
