TextureCoordsContainer Class Reference
Array of 2D texture coordinates. More...
#include <ccAdvancedTypes.h>
Inheritance diagram for TextureCoordsContainer:
Inheritance graph
Collaboration diagram for TextureCoordsContainer:
 TextureCoordsContainer ()
 Default constructor.
 Returns class ID. More...
virtual TextureCoordsContainerclone ()
 Duplicates array (overloaded from ccChunkedArray::clone.
- Public Member Functions inherited from ccChunkedArray< 2, float >
 ccChunkedArray (QString name=QString())
 Default constructor. More...
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
virtual ccBBox getMyOwnBB ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
 Sets normals visibility.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
- Protected Member Functions inherited from ccChunkedArray< 2, float >
 Save own object data. More...
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Member Function Documentation
virtual CC_CLASS_ENUM TextureCoordsContainer::getClassID ( ) const
inlinevirtual
Returns class ID.
Returns
class unique ID
Reimplemented from ccChunkedArray< 2, float >.
