Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
ccObject Class Referenceabstract
Generic "CloudCompare Object" template. More...
#include <ccObject.h>
Inheritance diagram for ccObject:
Inheritance graph
Collaboration diagram for ccObject:
 Default constructor. More...
 Returns class ID.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
 Returns flag state.
 Sets flag state. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
Additional Inherited Members
ccObject::ccObject ( QString  name = QString())
nameobject name (optional)
Member Function Documentation
bool ccObject::fromFile ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Reimplemented from ccSerializableObject::fromFile.
Be sure to call ccObject::ReadClassIDFromFile (once) before calling this method, as the classID is voluntarily skipped (in order to let the user instantiate the object first)
Reimplemented in ccHObject, and ccCustomHObject.
unsigned ccObject::GetLastUniqueID ( )
static
Returns last assigned unique ID.
Unique IDs are handled with persistent settings in order to assure consistency between main app and plugins!
QVariant ccObject::getMetaData ( QString  key) const
Returns a given associated meta data.
keymeta data unique identifier (case sensitive!)
Returns
meta data (if any) or an invalid QVariant
unsigned ccObject::GetNextUniqueID ( )
static
Returns a new unassigned unique ID.
bool ccObject::hasMetaData ( QString  key)
keyis the key to look for
Returns
true, if exists
virtual bool ccObject::isEnabled ( ) const
inlinevirtual
Returns whether the object is enabled or not.
Shortcut to access flag CC_ENABLED
virtual bool ccObject::isLocked ( ) const
inlinevirtual
Returns whether the object is locked or not.
Shortcut to access flag CC_LOCKED
CC_CLASS_ENUM ccObject::ReadClassIDFromFile ( QFile &  in,
short  dataVersion
static
Helper: reads out class ID from a binary stream.
Must be called before 'fromFile'!
bool ccObject::removeMetaData ( QString  key)
Returns
success
void ccObject::ResetUniqueIDCounter ( )
static
Warning: should be called only once, on program startup.
virtual void ccObject::setEnabled ( bool  state)
inlinevirtual
Sets the "enabled" property.
Shortcut to modify flag CC_ENABLED
void ccObject::setFlagState ( CC_OBJECT_FLAG  flag,
bool  state
protectedvirtual
Sets flag state.
flagobject flag to set
stateflag state
virtual void ccObject::setLocked ( bool  state)
inlinevirtual
Shortcut to modify flag CC_LOCKED
void ccObject::setMetaData ( QString  key,
QVariant  data
datadata
void ccObject::setUniqueID ( unsigned  ID)
virtual
Changes unique ID.
WARNING: HANDLE WITH CARE! Updates persistent settings (last unique ID) if necessary.
bool ccObject::toFile ( QFile &  out) const
protectedvirtual
outoutput file (already opened)
Returns
success
Reimplemented in ccHObject.
void ccObject::UpdateLastUniqueID ( unsigned  lastID)
staticprotected
