Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Attributes | List of all members
AsciiFilter Class Reference
ASCII point cloud I/O filter. More...
#include <AsciiFilter.h>
Inheritance diagram for AsciiFilter:
Inheritance graph
Collaboration diagram for AsciiFilter:
CC_FILE_ERROR loadCloudFromFormatedAsciiFile (const char *filename, ccHObject &container, const AsciiOpenDlg::Sequence &openSequence, char separator, unsigned approximateNumberOfLines, qint64 fileSize, unsigned maxCloudSize, unsigned skipLines=0, bool alwaysDisplayLoadDialog=true, bool *coordinatesShiftEnabled=0, CCVector3d *coordinatesShift=0)
static QSharedPointer
< AsciiSaveDlg
GetSaveDialog ()
 Returns associated dialog (creates it if necessary)
CC_FILE_ERROR saveFile (ccHObject *entity, FILE *theFile)
 Internal use only.
< AsciiSaveDlg
s_saveDialog
 Associated (export) dialog.
Member Function Documentation
CC_FILE_ERROR AsciiFilter::loadFile ( const char *  filename,
ccHObject &  container,
virtual
filenamefile to load
Returns
error
Implements FileIOFilter.
CC_FILE_ERROR AsciiFilter::saveToFile ( ccHObject *  entity,
virtual
filenamefilename
Returns
error
