Command line mode
-DISTANCES_FROM_SENSOR [-SQUARED]
Computes distances from every point of the cloud to the associated sensor origin (if any).
-SCATTERING_ANGLES [-DEGREES]
Computes compute the scattering angle from every point of the cloud (and its associated normal) w.r.t. to the associated sensor (if any).
-PLY_NO_SF_PREFIX
Prevents CloudCompare from prepending scalar field names with 'scalar_' when saving PLY files.
Note: since version 2.14 only. |
-PCD_OUTPUT_FORMAT {format}
