CloudCompare 3D entities
ccShiftedObject Class Reference
Shifted entity interface. More...
#include <ccShiftedObject.h>
Inheritance diagram for ccShiftedObject:
Inheritance graph
Collaboration diagram for ccShiftedObject:
Public Member Functions
 Default constructor. More...
 Copy constructor. More...
bool isShifted () const
template<typename T >
 Copy constructor.
 ~ccHObject () override
 Default destructor.
 Returns class ID. More...
bool isGroup () const
ccHObjectgetParent () const
 Adds a child. More...
void detachAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns selection behavior.
 Copy constructor.
 Returns object name. More...
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Destructor.
 ccDrawableObject ()
 Copy constructor.
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
 Sets associated GL display.
virtual void redrawDisplay ()
 Applies a display state.
Protected Member Functions
 Serialization helper (output)
 Serialization helper (input)
 Sets parent object.
 Save own object data. More...
 Returns flag state.
 Sets flag state. More...
Protected Attributes
CCVector3d m_globalShift
double m_globalScale
ccHObjectm_parent
 Parent.
Container m_children
 Children.
 Selection behavior.
 Dependencies map. More...
ccGLMatrix m_glTransHistory
bool m_isDeleting
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
ccColor::Rgba m_tempColor
 Temporary (unique) color.
bool m_colorIsOverridden
bool m_glTransEnabled
bool m_showNameIn3D
CCVector3d m_nameIn3DPos
bool m_nameIn3DPosIsValid
ccClipPlaneSet m_clipPlanes
Additional Inherited Members
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Shared pointer.
 Static factory. More...
 Sets the unique ID generator.
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
Shifted entities are entities which coordinates can be (optionally) shifted so as to reduce their amplitude and therefore display or accuracy issues.
◆ ccShiftedObject() [1/2]
ccShiftedObject::ccShiftedObject ( QString  name = QString(),
namecloud name (optional)
◆ ccShiftedObject() [2/2]
ccShiftedObject::ccShiftedObject ( const ccShiftedObject s)
default
Copy constructor.
sshifted object to copy
Member Function Documentation
◆ copyGlobalShiftAndScale()
void ccShiftedObject::copyGlobalShiftAndScale ( const ccShiftedObject s)
Copies the Global Shift and Scale from another entity.
sshifted entity to copy information from
◆ getGlobalScale()
virtual double ccShiftedObject::getGlobalScale ( ) const
inlinevirtual
Returns the scale applied to original coordinates.
Reimplemented in ccGenericMesh, and ccPolyline.
◆ getGlobalShift()
virtual const CCVector3d & ccShiftedObject::getGlobalShift ( ) const
inlinevirtual
Returns the shift applied to original coordinates.
See ccGenericPointCloud::setOriginalShift
◆ getOwnGlobalBB() [1/2]
ccHObject::GlobalBoundingBox ccShiftedObject::getOwnGlobalBB ( bool  withGLFeatures = false)
overridevirtual
Returns the entity's own global bounding-box (with global/non-shifted coordinates - if relevant)
Children bounding-boxes are ignored. May differ from the (local) bounding-box if the entity is shifted
Returns
global bounding-box
Reimplemented from ccHObject.
◆ getOwnGlobalBB() [2/2]
bool ccShiftedObject::getOwnGlobalBB ( CCVector3d &  minCorner,
CCVector3d &  maxCorner
overridevirtual
Children bounding-boxes are ignored. By default this method returns the local bounding-box! But it may differ from the (local) bounding-box if the entity is shifted.
[out]minCornermin global bounding-box corner
[out]maxCornermax global bounding-box corner
Returns
whether the bounding box is valid or not
◆ setGlobalScale()
void ccShiftedObject::setGlobalScale ( double  scale)
virtual
Sets the scale applied to original coordinates (information storage only)
Reimplemented in ccGenericMesh, ccMeshGroup, ccPolyline, and ccSubMesh.
◆ setGlobalShift() [1/2]
void ccShiftedObject::setGlobalShift ( const CCVector3d &  shift)
virtual
Sets shift applied to original coordinates (information storage only)
Such a shift can typically be applied at loading time. Original coordinates are equal to '(P/scale - shift)'
◆ setGlobalShift() [2/2]
virtual void ccShiftedObject::setGlobalShift ( double  x,
double  y,
double  z
inlinevirtual
