ccTorus Class Reference
Torus (primitive) More...
#include <ccTorus.h>
Inheritance diagram for ccTorus:
Inheritance graph
Collaboration diagram for ccTorus:
Public Member Functions
 ccTorus (PointCoordinateType insideRadius, PointCoordinateType outsideRadius, double angle_rad=2.0 *M_PI, bool rectangularSection=false, PointCoordinateType rectSectionHeight=0, const ccGLMatrix *transMat=0, QString name=QString("Torus"), unsigned precision=24)
 Default constructor. More...
 ccTorus (QString name=QString("Torus"))
 Returns class ID.
virtual QString getTypeName () const
 Whether drawing is dependent on 'precision' parameter.
virtual ccGenericPrimitiveclone () const
 Clones primitive.
 ccGenericPrimitive (QString name=QString(), const ccGLMatrix *transMat=0)
virtual void setColor (const colorType *col)
const ccGenericPrimitiveoperator+= (const ccGenericPrimitive &prim)
 Add operator. More...
virtual ccGLMatrixgetTransformation ()
virtual const ccGLMatrixgetTransformation () const
 ccMesh (ccGenericPointCloud *vertices)
 ccMesh (CCLib::GenericIndexedMesh *giMesh, ccGenericPointCloud *giVertices)
 ccMesh constructor (from a CCLib::GenericIndexedMesh) More...
virtual ~ccMesh ()
 Default destructor.
virtual void setAssociatedCloud (ccGenericPointCloud *cloud)
virtual ccMeshclone (ccGenericPointCloud *vertices=0, ccMaterialSet *clonedMaterials=0, NormsIndexesTableType *clonedNormsTable=0, TextureCoordsContainer *cloneTexCoords=0)
 Clones this entity. More...
virtual ccGenericPointCloudgetAssociatedCloud () const
 Returns the vertices cloud.
virtual void refreshBB ()
 Forces bounding-box update.
virtual bool interpolateNormals (unsigned triIndex, const CCVector3 &P, CCVector3 &N)
virtual bool interpolateColors (unsigned triIndex, const CCVector3 &P, colorType rgb[])
virtual bool getColorFromMaterial (unsigned triIndex, const CCVector3 &P, colorType rgb[], bool interpolateColorIfNoTexture)
virtual bool getVertexColorFromMaterial (unsigned triIndex, unsigned char vertIndex, colorType rgb[], bool returnColorIfNoTexture)
virtual unsigned maxSize () const
 Returns max capacity.
virtual void forEach (genericTriangleAction &anAction)
virtual void placeIteratorAtBegining ()
virtual CCLib::GenericTriangle * _getNextTriangle ()
virtual CCLib::GenericTriangle * _getTriangle (unsigned triangleIndex)
virtual
CCLib::TriangleSummitsIndexes *
getNextTriangleIndexes ()
virtual
getTriangleIndexes (unsigned triangleIndex)
virtual void getTriangleSummits (unsigned triangleIndex, CCVector3 &A, CCVector3 &B, CCVector3 &C)
virtual unsigned size () const
virtual void getBoundingBox (PointCoordinateType bbMin[], PointCoordinateType bbMax[])
virtual const
getTriangleIndexes (unsigned triangleIndex) const
virtual ccBBox getMyOwnBB ()
 Sets associated GL display.
virtual void shiftTriangleIndexes (unsigned shift)
bool reserve (unsigned n)
bool resize (unsigned n)
virtual bool hasTriNormals () const
virtual void getTriangleNormalIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual bool getTriangleNormals (unsigned triangleIndex, CCVector3 &Na, CCVector3 &Nb, CCVector3 &Nc) const
virtual NormsIndexesTableTypegetTriNormsTable () const
virtual void setTriNormsTable (NormsIndexesTableType *triNormsTable, bool autoReleaseOldTable=true)
virtual void clearTriNormals ()
 Removes per-triangle normals.
virtual bool hasMaterials () const
virtual const ccMaterialSetgetMaterialSet () const
virtual int getTriangleMtlIndex (unsigned triangleIndex) const
virtual bool convertMaterialsToVertexColors ()
virtual void setMaterialSet (ccMaterialSet *materialSet, bool autoReleaseOldMaterialSet=true)
virtual bool hasTextures () const
virtual TextureCoordsContainergetTexCoordinatesTable () const
virtual void getTriangleTexCoordinates (unsigned triIndex, float *&tx1, float *&tx2, float *&tx3) const
virtual bool hasPerTriangleTexCoordIndexes () const
virtual void getTriangleTexCoordinatesIndexes (unsigned triangleIndex, int &i1, int &i2, int &i3) const
virtual void setTexCoordinatesTable (TextureCoordsContainer *texCoordsTable, bool autoReleaseOldTable=true)
virtual bool computeNormals (bool perVertex)
 Computes normals. More...
virtual bool computePerVertexNormals ()
virtual bool computePerTriangleNormals ()
bool laplacianSmooth (unsigned nbIteration=100, PointCoordinateType factor=static_cast< PointCoordinateType >(0.01), CCLib::GenericProgressCallback *progressCb=0)
 Laplacian smoothing. More...
virtual ccMeshcreateNewMeshFromSelection (bool removeSelectedFaces)
 Swaps two triangles. More...
virtual ~ccGenericMesh ()
 Destructor.
 Sets normals visibility.
 Enables polygon stippling.
 Samples points on a mesh.
virtual ~ccHObject ()
 Default destructor.
ccHObjectgetParent () const
 Adds a child. More...
ccHObjectfind (int uniqueID)
void detatchAllChildren ()
void removeChild (int pos)
void removeAllChildren ()
 Removes all children.
 Returns child index.
 Swaps two children.
int getIndex () const
 Shortcut: returns last child.
 Returns bounding-box. More...
void notifyGeometryUpdate ()
 Returns selection behavior.
 Returns object name.
 Sets object name.
 Returns object unique ID.
 Changes unique ID. More...
bool isGroup () const
bool isLeaf () const
bool isCustom () const
bool isHierarchy () const
 Desctructor.
 ccDrawableObject ()
 Sets entity visibility.
 Toggles visibility.
 Selects/unselects entity.
 Sets colors visibility.
virtual void toggleColors ()
 Toggles colors display state.
virtual void toggleNormals ()
virtual void toggleSF ()
 Toggles SF display state.
virtual bool sfShown () const
virtual void redrawDisplay ()
Protected Member Functions
 Save own object data. More...
virtual bool buildUp ()
 Builds primitive. More...
 Inherited from ccGenericMesh.
ccGenericPrimitivefinishCloneJob (ccGenericPrimitive *primitive) const
ccPointCloudvertices ()
 Returns vertices.
bool interpolateNormals (unsigned i1, unsigned i2, unsigned i3, const CCVector3 &P, CCVector3 &N, const int *triNormIndexes=0)
bool interpolateColors (unsigned i1, unsigned i2, unsigned i3, const CCVector3 &P, colorType rgb[])
 ccMesh_extended_call1 (showNormals, bool, showNormals_extended)
 Sets parent object.
 Returns flag state.
 Sets flag state. More...
Protected Attributes
PointCoordinateType m_insideRadius
 Inside radius.
PointCoordinateType m_outsideRadius
 Outisde radius.
bool m_rectSection
 Whether torus has a rectangular (true) or circular (false) section.
PointCoordinateType m_rectSectionHeight
 Rectangular section height (along Y-axis) if applicable.
double m_angle_rad
 Subtended angle (in radians)
ccGLMatrix m_transformation
unsigned m_drawPrecision
ccGenericPointCloudm_associatedCloud
 associated cloud (vertices)
NormsIndexesTableTypem_triNormals
 Per-triangle normals.
 Texture coordinates.
ccMaterialSetm_materials
 Materials.
unsigned m_globalIterator
 Iterator on the list of triangle summits indexes.
CCLib::SimpleRefTriangle m_currentTriangle
ccBBox m_bBox
 Bounding-box.
bool m_triNormsShown
bool m_materialsShown
bool m_showWired
 Wireframe display mode.
bool m_stippling
 Polygon stippling state.
ccHObjectm_parent
 Object's parent.
Container m_children
 Object's children.
 Selection behavior.
 Dependencies map. More...
QString m_name
 Object name.
unsigned m_flags
 Object flags.
QVariantMap m_metaData
 Associated meta-data.
bool m_visible
bool m_selected
bool m_lockedVisibility
bool m_colorsDisplayed
bool m_normalsDisplayed
bool m_sfDisplayed
colorType m_tempColor [3]
 Temporary (unique) color.
bool m_colorIsOverriden
ccGLMatrix m_glTrans
bool m_glTransEnabled
bool m_showNameIn3D
Additional Inherited Members
enum  MESH_SCALAR_FIELD_PROCESS { SMOOTH_MESH_SF, ENHANCE_MESH_SF }
enum  DEPENDENCY_FLAGS {
  DP_PARENT_OF_OTHER = 24
 Dependency flags. More...
 Behavior when selected.
 Static factory. More...
static bool WriteError ()
static bool ReadError ()
static bool MemoryError ()
static bool CorruptError ()
typedef GenericChunkedArray
< 3, unsigned >
< 1, int >
< 3, int >
< 3, int >
Torus (primitive)
3D torus primitive (with circular or rectangular section)
ccTorus::ccTorus ( PointCoordinateType  insideRadius,
double  angle_rad = 2.0*M_PI,
bool  rectangularSection = false,
PointCoordinateType  rectSectionHeight = 0,
const ccGLMatrix transMat = 0,
QString  name = QString("Torus"),
unsigned  precision = 24
Torus is defined in the XY plane by default
insideRadiusinside radius
outsideRadiusoutside radius
angle_radsubtended angle (in radians)
rectangularSectionwhether section is rectangular or round
rectSectionHeightsection height (if rectangular torus)
namename
precisiondrawing precision (main loop angular step = 360/(4*precision), circular section angular step = 360/precision)
ccTorus::ccTorus ( QString  name = QString("Torus"))
Simplified constructor.
For ccHObject factory only!
Member Function Documentation
bool ccTorus::buildUp ( )
protectedvirtual
Builds primitive.
Returns
success
Implements ccGenericPrimitive.
bool ccTorus::fromFile_MeOnly ( QFile &  in,
short  dataVersion,
int  flags
protectedvirtual
Loads own object data.
ininput file
dataVersionfile version
Reimplemented from ccGenericPrimitive.
bool ccTorus::toFile_MeOnly ( QFile &  out) const
protectedvirtual
